08-22-2022 08:43 AM
08-22-2022 08:14 PM
08-22-2022 10:48 AM
@iulix wrote:Is less than 90 days.
I emailed customer support.
My account page doesn't work.
Please close the topic.
@iulix the topic cannot be closed.
you "emailed" Customer support, you meant you opened ticket or messaged them? Check your Community inbox here for their reply, they reply here, not email
08-22-2022 10:47 AM
Can you login to the rewards page? That would confirm that you have the right login id and password. Did you possibly have any fraud activity on your credit card recently?
Called who?
08-22-2022 10:43 AM
I am on automatic payments.
I called to suspend in June.
And now having lots of issues getting re-activated.
I email support as well.
08-22-2022 10:41 AM
08-22-2022 10:00 AM
Use the phone to dial 611 to get a status report of your acct. Using your on-file credit card, you can also make payment and reactivate the acct as long as it hasn't been longer than 90 days since last plan expired.
If it's been in suspension for 90 days or longer, that acct is now closed for good and you'll need a new sim to start a new account.
As of January...the Rewards program is gone and as a new acct...you can only get the Points program.
How long has your acct been suspended ?
08-22-2022 09:13 AM
If your account was suspended due to no pay less than 90 days, you should log in, pay the bill and account will be reactivated.
08-22-2022 08:47 AM
@iulix You need to reactivate the account yourself
Can you login to My Account? If so, please login, click the button "Reactivate my plan". It will bring you to payment page. Just manually load Amount due. Once payment goes through, logoff from My Account and reboot your phone.
If you are unable to login to My Account, please open ticket with PM Support and they will sort out the login for you
1. For faster response (2-48 hours), use this direct link: https://publicmobile.ca/chatbot.
**Start with typing "Forgot Login Information", click "Contact Us", click "Click here to submit a ticket".
2. Or Private message to the CS Agent: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
