2 weeks ago - last edited 2 weeks ago
hello, I recently purchased an esim public mobile plan. But unfortunately my phone is not esim compatible. Please cancel my subscription and refund the amount. Thank you very much.
2 weeks ago
You should remove your personal information this is a public forum anyone can see it. Use the down arrow on the right of your post to edit it.
2 weeks ago
you dun really have to cancel the subscription, you can buy a physical sim and change.
But whether to change to physical sim or continue to ask for cancellation and refund, you still message PM and tell them what you like to do from here
Since you cannot properly login, you won't be able to open the preferred Chatbot ticket. So, you will need to message them here:
