12-19-2022 07:36 PM
Pin # where do I find it for to Port my phone# from public Mobile to a new carrier?
I found the account # but the PIN is on the same page. Is that your PIN #
Thanks Travis
12-19-2022 07:39 PM
PIN isn't needed for number porting. Skip it in instances when you have the account number.
12-19-2022 07:39 PM - edited 12-19-2022 07:40 PM
@Kojack88 you do not provide your PIN to port your number to another provider
Instead, you should provide your PM account number. To get the account number, go to My Account , Profile page
if you really need your PIN number, which I doubt, you can also reset it under Profile page and then provide them the PIN
12-19-2022 07:38 PM
@Kojack88 - I believe that normally, you get your PIN in the initial (welcome) message from PM.
12-19-2022 07:38 PM
Sign into pm and it will be there under my profile with ur password aswell
