10-26-2020 06:33 PM - edited 01-05-2022 03:55 PM
I'm using an old model of sony Ericsson w205. How do I know if the phone is unlocked?
I got a new number I didn't transfer old number.
10-26-2020 07:04 PM
Hi @twinx
You need 3g phone with bands 850 and 1900
I'm sure you can find something in kijiji fast
I heard you can get a cheap phone on costco, not in the mobile section but where accessories are
Any phone working with Telus or bell will work too, bell phones just must be unlocked
10-26-2020 06:51 PM
As mentioned above, your phone will not work on Public mobile network. It is a 2G phone only. Unable to support 3G or 4G bands.
https://www.gsmarena.com/sony_ericsson_w205-2774.php
Technology | GSM |
2G bands | GSM 900 / 1800 |
GSM 850 / 1900 -W205a |
Might work on Rogers/Fido network at the present moment. Rogers and Fido does support GSM until the end of this year. Afterwards, the 2G network is suppose to be decommissioned.
10-26-2020 06:39 PM
@twinx wrote:I'm using an old model of sony Ericsson w205. How do I know if the phone is unlocked?
That phone won't work here.
10-26-2020 06:38 PM
