Phone rings only three times
Ava14
My phone only rings three times before going to voicemail. How do I change it so that I get It to ring many more times. I have an iPhone.
Ava14
Thanks so much!
HI @Ava14
yes, some people reported that this trick seem to be not working anymore.  But I think it is due to Conditional forwarding.  Ask PM support agent to check.
submit a ticket with CS Agent using Chatbot here:
             Type the question "Submit ticket", Then click the following in order: "Contact Us" ,  "Other",  "Log In".
If any issue with ticket submission, you can submit  ticket by direct message:
Ava14
Hi I tried entering the code but it kept saying error. Do I have to enter the plus sign too or was that just to denote that I had to enter my phone number?
hi @Ava14
Try this.
**61*+1YourLocalNumberVoicemail*11*5#
The last digit 5 is 5 seconds till voicemail. Change it to a number you want in 5 increment up to 30.
