Phone plan for visitors
pckku
Please let me know whether or not I go to Walmart, purchase a PM sim card and activate it to get a new number, without using a physical phone. The PM sim card will be for my visitors coming to Canada in about one week. I am sure their current phone WILL work onPublic Mobile network as they have the same phone as mine. Can I activate a new sim card without their phone?
1 ACCEPTED SOLUTION
Accepted Solutions
meocon
@pckku Yes you can activate a new sim card with PM without a phone. Also, don't forget PM currently has some perfect promos. Activate at Walmart with Talk+Text plan you will get $20 credit bill + free sim + $10 for a friend referral as well. hurry this week only
13 REPLIES 13
meocon
MacMe
Yes, you can buy a SIM and activate it without a phone.
wetcoaster
You don't need an a phone / IMEI for signing up with Public Mobile, obviously you'll need a device to use the SIM.
I would put the freshly activated SIM into your phone to make sure everything works as expected.
pckku
Thank you.  And will I also getting the $10 back from Walmart if I activate the sim there?
meocon
@pckku yes you will get $10 for friend referral if you don't have any friend from PM to refer you can send me a private message I can give you my phone number.
https://productioncommunity.publicmobile.ca/t5/Announcements/Friendship-Forever-Celebrate-Your-BFF-T...
Orz
Yes, I did just that and it works. I opened a new line for my dad and did not bring a phone with me so I walked out of the store with only the sim card after everything said and done.
Although it is a good idea to bring a working phone to test whether the sim activates and works properly on the spot. That may save you one trip should anything happen.
pckku
Thank you all for the great help!!!
Will go out and buy the sims from Walmart this week to take advantage of the $10 credit promotion for the sim card.
Dougmania
No you don't need a phone when you sign up. Just go into walmart, and come out with an activated sim. Since it is free SIM and up to $32 bonus credits it is a great time to buy at Walmart.
1. Go to Walmart store and ask to sign up for public mobile. You get $20 Credit when you sign up at walmart.
2. Use your email as a login name (if you are going to port from PC mobile or Koodo, make sure to use a different email address)
3. Enter your referral number. If you don’t have one, I can give you one. You need a referral for the $10 credit.
4. Pick your plan and phone number and enter your credit card information when signing up and choose to Auto Pay and activate your SIM. You get $2 credit for doing autopay. You have to pay for the first 30 days.
5. Create and log into your publicmobile.ca account to find your credits within 72 hours.
