Phone number not displayed when making a call
Shivpatel
Hello,
When making a phone call, my phone number is not displayed.
13 REPLIES 13
Shivpatel
Not android or iPhone but this worked.
Thanks
dust2dust
What is the make and model of the phone? Are you just doing this testing calling one phone? Or others as well?
Shivpatel
Sorry it's unknown number that is displayed
Shivpatel
No I did not use *67
*82 says I don't have minutes
Shivpatel
Private Number
Shivpatel
It is a regular flip phone
Everyone is staying that they don't see the name or number when I make a call.
I recently had the service paused due to a credit card change but once I enabled the service again with a new card the issue occured.
dust2dust
Try manually dialing *31# and then the phone number you're testing with. See if your number shows up.
So iphone or Android?
Shivpatel
Name is displayed as Private Number , I have not disabled anything.
HALIMACS
For Android:
Manage your caller ID during calls - Android - Google Voice Help
For iPhone:
  • Settings>Phone>Show My Caller ID>
  • toggle on or off
HI @Shivpatel
or try this
 iPhone:
Open the Settings app and scroll down to tap on the Phone option.
Tap Show My Caller ID, then turn the toggle off to hide your number.
Show My Caller ID option from iPhone Settings
on an Android Device
Different Android phone could be different, but this is the general idea:
Launch the Phone app and open the Menu in the top-right corner.
Go into Settings, then scroll down to Supplementary Services. Depending on your particular device, you may need to go to Calls > Additional Settings.
Tap Show my caller ID and choose to Unhide number from the popup menu.
HALIMACS
@Shivpatel
What are people telling you displays on their device?
HI @Shivpatel   you number was not showing in the other side when you call?
did you use *67 earlier?
try dial *82 before the number you want to call
dust2dust
Displayed where? Do you have the hide your number set on or off?
