Phone number got Stolen ?
a3a45471
Received  a call said  my PM phone number was used in India for scam.
  • Checked my usage records and everything normal. Should I  change my number to avoid  any trouble ?
  • My old phone number belong to a Indian lady
darlicious
@a3a45471
You might get more than the average nuisance calls for awhile. If you are not beholden to the number and only had it a short while you can consider changing it.  Maybe when you're bored you can peruse the available numbers and see if you come across a cool one you might like....you can change your number up to 4 times per 30 days if you really want. Just make sure you have a rock solid 2FA back up for anything that has your current number listed so you can safely update them with your new number.
To contact customer support : Submit a support ticket via SIMon the chat bot Click here
Or if you cannot submit a ticket via SIMon then Click here   ....for additional member supplied info.
@a3a45471   Very likely you can ignore that.  It is likely a Caller ID Spoofing trick
https://crtc.gc.ca/eng/phone/telemarketing/identit.htm
Very commonly use trick by scammer, but nothing to worry about.
Just like letter mail, someone can put your address on the return address and send to another person , you cannot do anything but there is no harm to you at all.
@a3a45471  - sounds like someone spoofed your phone number.
I would not be too concerned. Spammers can do this to make is seem like they are calling from local numbers.
I think your number was chosen for one, or more.
Nice, that someone called you to tell you about it, I guess. 🙂
