05-14-2022 06:05 AM
My payment was automatically taken on May 10 and I haven’t had any service (phone or text) since May 11. Pubic Mobile doesn’t even show up in my carrier options on my iPhone anymore (iSO 15.4.1). I’ve checked for updates (my husband’s Public Mobile service on his iPhone is working), rebooted, removed the SIM and nothing’s working. I’m not restoring my phone to factory settings!
I’ve had this problem several times since September where they take my payment automatically and then suspend my service for a day. FRUSTRATING but this time it’s 4 days.
To make it worse, you can’t call for help and their service isn’t open for chat till 10 am AST.
I changed my backing from visa debt to Mastercard and maybe that’s the issue. I don’t know but I’m beyond frustrated.
05-14-2022 09:12 AM
It worked!!!
05-14-2022 08:42 AM
That says it’s going to reset my phone to factory settings. I don’t want to loose all my data, saved passwords, contacts, photos, etc.
05-14-2022 08:41 AM
@SCIWC - can you swap your SIM card into your husband's phone and use your husband's SIM card in yours and see if both or neither work?
05-14-2022 08:41 AM
@SCIWC if you tried network reset and didn't work, try to put a sim in another phone
If that still not work, open a ticket with PM and have them to confirm. If they say it might be because of faulty sim, then ask them to reimburse the SIM cost and you go and get a new SIM card
To open ticket with PM Support:
1. If you have access to My account: At https://publicmobile.ca/chatbot.
2. If you don't have access to My Account or have trouble with Chatbot: Private message CS Agent at:
05-14-2022 08:39 AM
@Esjilv I tried that and it didn’t work.
05-14-2022 08:38 AM
To Reset of your device's Network Settings see below.
This also resets Wi-Fi networks and passwords, cellular settings, and VPN and APN settings that you've used before.
Iphone:
To Reset Network Settings, begin by opening the Settings app. Next, tap General -> Transfer or Reset iPhone -> Reset -> Reset Network Settings. and enter your passcode.
Your iPhone will reset network settings and restart itself.
05-14-2022 08:36 AM
What is a network reset?
I’ve powered off several times and service did come on for a blip. If I leave the automatic network selection turned on, the phone attaches to AT&T.
I did take out the SIM but while the phone was on.
05-14-2022 08:36 AM
@SCIWC - you may also try turning on airplane mode for about a minute, then go back to regular mode, and see if that resets your network connection.
05-14-2022 08:33 AM - edited 05-14-2022 08:34 AM
@SCIWC wrote:
@SCIWC Try to reset the sim (power off phone, take it out for a minute and put it back and power up)
if still fails, try a network reset
if still fails, try the sim on another phone
Again, it is likely not your account but an issue with your phone or your SIM.
Putting your SIM in another phone could also force a SIM reprovision and that could resolve the problem
05-14-2022 08:32 AM
05-14-2022 08:32 AM - last edited on 05-14-2022 08:38 AM by computergeek541
edited by computergeek541: images containing referral code removed
05-14-2022 08:31 AM
05-14-2022 08:24 AM
@SCIWC wrote:Public Mobile is not listed as one of my Service Provider options in my phone settings, I can’t make or receive calls or texts.
@SCIWC That could mean it might be either a device issue or SIM card
Did you try to put your SIM in another phone and see if it works? If it works, then it is the device.
Also, what is the status showing on the phone? Any error message like "SIM not provisioned", "No network", "No SIM"?
05-14-2022 08:22 AM
It’s active and no funds available and my next payment is June 9.
05-14-2022 08:22 AM
Checked and it is.
05-14-2022 08:21 AM
I was using a credit card up until September and never had a problem. I switched to a debit visa and 3 months (since Sept) it said I didn’t pay, cut off my service and I had to pay manually. The other months, the auto pay took the payment and no issues. Then this month, it took my payment, shows my account as active but I have no service.
05-14-2022 08:18 AM
I checked and the money was definitely taken out of my bank account on May 10. In my PM account, it shows as active and I even received a text thanking me for my payment. Public Mobile is not listed as one of my Service Provider options in my phone settings, I can’t make or receive calls or texts.
05-14-2022 08:09 AM - edited 05-14-2022 08:10 AM
So to be certain, you are trying to send text messages and make phone calls and you are unable to?
Or are you just seeing this messaging in your self serve on the eve of renewal and thinking that they have suspended your account?
This message always appears on the eve of renewal and it's just Public Mobile's way of renewing accounts:
05-14-2022 08:06 AM
@SCIWC -
Perhaps it is connected to the change of payment card if that is when this started. But depending on what your account status says when you have no services that could tell you something...If Active status and service kicks in on it's own that is weird.
This has been going on since September during / at renewal time? And does your account say registered for Dynamic Autopay?
Because of this happening for months, I would suggest to contact CSA and tell them the issues you have been having.
Public Mobile Representatives customer support agents (CSA) can be contacted, by either two methods, found here:
05-14-2022 07:04 AM
Go into your account and make sure auto roll is activated.
05-14-2022 06:33 AM
You have logged into your account and confirmed it's status? It's suspended? Is your payment in your available funds? Or active and you have no working services? Which plan do you have?
To contact customer support : Submit a support ticket via SIMon the chat bot Click here
Or if you cannot submit a ticket via SIMon then Click here ....for additional member supplied info.
