Phone has no serive more time then it has
2045589844
Phone has no service more then it has service. who to get a hold of to fix this?
11 REPLIES 11
Not too many old style non smartpuone might work well anymore because of the VoLTE requirements.  Before you buy a new one, done to the community and check first.  Or check with PM VoLTE checker
https://www.publicmobile.ca/en/on/get-help/articles/volte
2045589844
Thanks I will look for one.
Hi @2045589844
you will need something like ZTE Cymbal 2
2045589844
Thanks will look into another phone. I like he small flip phones.
hi @2045589844
too old the phone, you need a new one.
yes, too old for any carrier.  You are lucky PM still has 3G but it will be gone in a year or so.  And even before it is completely gone, you will see your voice calls more and more unreliable
2045589844
LG-C441
hi @2045589844
what phone is that?
2045589844
It goes into a no seriveice or emergency only  like I am out of the satelite field
hairbag1
@2045589844
Public Mobile is more of a DIY type of service. The Community Forum is made up with customers just like you and me. Between us all, we can usually sort of whatever is the problem you're experiencing. Can you give a bit more detail other than "no service more..". Is the talk features failing ? Are you a new customer or has this been a problem for awhile ? Are both messaging and data affected negatively or is it just the talk that fails ?
The more info you can provide, the quicker we can help.
2045589844
thanks
hi @2045589844
you might want to ask PM support to update the username if that is your phone number.  if not, you will find the service really working as people will be testing it for you
and what services have problem? voice?  What phone do you have? Check if your phone can use VoLTE here
