06-07-2023 04:03 PM
07-02-2023 12:39 PM - edited 07-02-2023 12:41 PM
@Moe777 you can simply dial *611 ftom your phone and load the voucher
or you can login My Account and then go to Payment page, click Redeem Payment Voucher or use this direct link
https://myaccount.publicmobile.ca/en/account/payment/payvoucher
07-02-2023 12:36 PM
i can not find it in the new look, where to add voucher for my account
06-07-2023 05:35 PM
Thank you very much 🙂 ! The phone number worked and the voucher worked too , it is add it to my account. THANK YOU !
06-07-2023 05:26 PM
@Niina- If you've tried a couple times now then you would need to wait about an hour and try again...twice. Then wait again. When and where did you buy the voucher? Can you also try using 1-855-4pu-blic.
Yes, support can be asked to enter the voucher.
06-07-2023 05:24 PM
dial 611 does not work, you can dial and put in the voucher pin, but it does not add it to the account.
Is there a way the voucher can be refunded it or can rep from Publicmobile add it to the payee's account ??
06-07-2023 05:22 PM
Is there a way the voucher can be refounded it or can a eep from Publicmobile add it to the payee's account ??
06-07-2023 04:55 PM
If you are activating a new SIM, you will need to contact a CS_Agent to help you active the SIM.
If you are just paying your monthly bill, dial 611 and enter the voucher number.
06-07-2023 04:18 PM
@Ozzy and where you got your voucher from? Vouchers from some places have a 24 hours wait tome. Best to get it from SDM/711/Shell/London drugs, their vouchers can be loaded to PM system immediately.
But if you got it elsewhere already, you might have to wait the full 24 hours first and re-try
06-07-2023 04:06 PM
@Ozzy , what is your question? It is possible to pay with a voucher. You can call 611 on your phone, use the app or login from a desktop browser (use incognito mode).
