03-23-2023 06:53 PM - last edited on 03-24-2023 06:58 PM by computergeek541
Account says active buy can't call. I get emergency calls only message. I paid $25 with a voucher yesterday. Thx.
03-24-2023 07:22 PM
Interesting @Boobies1965 , glad customer support was able to resolve. I wonder what they had to do to get you going again. Sometimes a reprovisioning at their end gets things rolling again.
Welcome back!!!
03-24-2023 06:11 PM
One of their tech/engineers fixed everything on his end. My service is up and working now. Thx for your, and everyone else's help. 🙂
03-24-2023 01:18 PM
thanks @Boobies1965 for the update At least they see the fund there
Ask them for compensation for the lost of service for couple days
03-24-2023 01:16 PM
Yes.. They got back to me. They reset everything on their end and still no go. They think it "may" be a system glitch after I paid with a voucher. They referred my issue to their programming/software. Said it would be up to 48hrs for response.
03-24-2023 08:11 AM
@Boobies1965 have you open a ticket with PM Support yet? Did PM support come back and tell you what was the problem?
03-24-2023 07:18 AM
BTW - Thanks for all your help.
03-24-2023 07:17 AM
I bought the fun from a reputable person 5 years ago and it has been work well since on SaskTel and then Public.
03-24-2023 06:00 AM
Was the device acquired brand new or used? If used, was it from a reputable source or unknown?
Check to see if blacklisted:
03-23-2023 11:16 PM
Only one SIM card slot.
03-23-2023 11:15 PM
I submitted a ticket. My account says active til April 23rd plus I have a $25 account balance but still only emergency calls allowed and texts are shutdown too. I imagine data is not accessible to but haven't tried it.
03-23-2023 08:29 PM
does your cell phone have dual sim slots ? If so, power down the phone and remove sim from current slot and reinstall in other...restart the phone.
Does that help ?
03-23-2023 08:26 PM
Definitely send this to the CSA's for investigation, @Boobies1965
03-23-2023 07:42 PM
Refreshed little icons and still says active for the next month. Telus outage maps are clear for my Sask region.
03-23-2023 07:30 PM
1.855.4public gets me the emergency calls only pop up on the screen just like *611.
03-23-2023 07:20 PM
Check to see if they is an outage in your area:
03-23-2023 07:19 PM
@Boobies1965 how about Mobile data?
*611 is currently having issues, so it is not just you.
Try calling 1.855.4PUBLIC, enter your phone number and see if it tells you your account is active.
if it says active but still problem, please open ticket with PM support
03-23-2023 07:12 PM
I can't even call *611. I get emergency calls only message graphic. Texts don't work either.
03-23-2023 06:58 PM
Hi @Boobies1965 could be unrelated with renewal but a problem with the network. There are couple complaints already
Please submit ticket with PM agent and they can check
at : https://publicmobile.ca/chatbot.
First type Contact,
from the list of , choose "Other"
03-23-2023 06:54 PM - edited 03-23-2023 06:57 PM
When you log into the self-serve, make sure to tap the little refresher icons to make sure you're not seeing an outdated version of the page.
When you call 611 from your device, what messaging do you hear?
Also, does your texting and data work?
EFIT: Try rebooting your device, resetting Network connections, and toggling airplane mode on and off
If both 611 and the self-serve page confirm your account status is active, there could also be an outage in your area. Google the Telus outage map and select your location to check.
