01-21-2022 08:17 AM
Twice since the change to the new forum format, I have received notification that my reply was selected as the solution. The most recent I captured as seen below. When I visit the page though, my reply is not the chosen one and in the case below the one marked "Accepted" by @HALIMACS doesn't answer the original question. The other occasion I was notified that @Luddite had accepted my response and again, a different one is actually marked in the thread. Anyone else experiencing this?
01-21-2022 08:23 AM
HI @kb_mv
if you check the main Notification page , does it show the same thing?
https://productioncommunity.publicmobile.ca/t5/notificationfeed/page
I am not sure about that "Recent Notification", but for the Notification pop up, I notice that some pop-up are old notification. So, it is not very accurate to me anyway. However, the notification page has been accurate and working well for me
01-21-2022 08:35 AM
@hTideGnow Both notifications mentioned above show up as my two most recent.
Though they both say accepted a solution as opposed to mine.....
01-21-2022 08:44 AM
HI @kb_mv, but the first posts you show that HALIMACS accepted solution was an old post Feb 2021 post but HALIMACS edited on Jan 5 2022, maybe you can ask if Halimacs accepted solution yesterday or way back?
01-21-2022 08:50 AM
@hTideGnow That is why I tagged @HALIMACS and @Luddite . Regardless of when they were done, why show up now indicating new solutions? As I said, this only happened since the new forum change. Is it connected? Interested to see if it has happened to anyone else. Having my solutions accepted or not isn't an issue for me. I am on here so little lately. I was just curious.
01-21-2022 08:57 AM - edited 01-21-2022 08:58 AM
Indeed @HALIMACS did accept or possibly changed the solution to that thread yesterday as I believe some new information may have come to light.
I asked the same question as you the other day....I was getting excited seeing my post chosen as a solution on the landing page only to discover either the OP or @Luddite had in fact often chosen Someone's--Solution but it certainly wasn't mine! After about the 10th one in a row I created the thread and asked the question.
I chose @ShawnC13 's solution.....that @Luddite was just messing with my head!
01-21-2022 10:27 AM
@kb_mv Depending on the speed of the notification system some of these are likely me. Sometimes I notice a better answer after clicking Solution and make a change. These would be within a few minutes of each other, not days apart.
I do not change an OP's selection unless it's an inappropriate self solution.
01-21-2022 10:30 AM
Lol....so you really are messing with my head!!😭😲
01-21-2022 10:36 AM
@darlicious : Your signature copy/paste isn't quite ingrained habit yet. 🙂
01-21-2022 10:41 AM - edited 01-21-2022 10:42 AM
No I was just giving @Luddite the benefit of not seeing it. I programmed it special just for him!
