07-27-2022 05:42 PM
I just went on Public Mobile’s plan. I am not getting any phone calls. People have called my land line saying they keep on going to voice mail. When I check voice mail, there are no messages.
07-27-2022 07:18 PM
@Mare2 wrote:I just went on Public Mobile’s plan. I am not getting any phone calls. People have called my land line saying they keep on going to voice mail. When I check voice mail, there are no messages.
@Mare2 - you must make sure your landline is active to port over to Public Mobile. Once the port is complete the old account should automatically close.
If you have activated a new account and transferred over from another provider, note that incoming calls are usually the last to port over.
When the incoming calls start coming to the Public Mobile sim card, that is a good indication the port is complete.
If still issues, after the alloted time to port a number over, submit a ticket with Public Mobile representatives (CSA) for help; click this link: to request the transfer of your number over to Public Mobile.
See helpful info. here: https://www.publicmobile.ca/en/bc/get-help/articles/port-fraud-protection
07-27-2022 05:56 PM - edited 07-27-2022 05:57 PM
If you ported your landline to PM, it will take about 48 hours to complete the porting.
Contact a CS_Agent to see where PM is in the porting process.
07-27-2022 05:48 PM
manually select network 3G only or WCDMA only
and rebooting device
07-27-2022 05:46 PM - edited 07-27-2022 05:46 PM
@Mare2 How long ago did you activate your line? Did you request to port in your number? If yes, do you currently have service on your old sim card? You should've got a text message to authorize the port in request, did you get that? What about data services? Do you get signal on the Public Mobile sim at all?
