Not Receiving Phone Calls & Messages after porting the number
Alad
After porting the number I am not receiving any phone calls or messages. I am able to make a call thogh.
Can I get help please?
7 REPLIES 7
Gr80
please send number
Alad
Thanks
@Alad wrote:
Yesterday
@Alad
Then your port was not successful.  I will private message you the Telus team porting team phone number.  They might not be working at the present time, so you might need to call tomorrow morning.
Alad
Yesterday
Alad
I did remove it but I need to make sure if it is showing as a primary sim manager.
Thanks
Sansan
Did you remove your previous SIM card from your phone? Check to make sure that the Public Mobile SIM is showing as primary in the sim manager ?
Dunkman
@Alad
How long ago did you port your number?  It can take 1-2 hours for port to be completed.
Did you respond "yes" to your old carrier's port request text?
