02-02-2025
11:55 AM
02-02-2025
03:19 PM
computergeek541
02-02-2025 12:32 PM
It is an E-Sim. There is no physical sim card to put into another phone
02-02-2025 12:31 PM
did you try your sim card in another phone?
02-02-2025 12:30 PM
I am up to date with my payments, they already took it out.
I did change my plan in end of December.. but why would it cancel out, a month later.
Also, I did open a ticket.
Hopefully they cn figure it out, as I do require my phone for work.
02-02-2025 12:26 PM - edited 02-02-2025 12:29 PM
@Jerrica wrote:I have had this e sim since March of last year.
I would like to think its still compatible with the same phone it's been on.
Also, network didn't fix it. Nor did restarting my phone
As dumb as this may sound, have you tried dialing 611 from your phone or logged in through the app to confirm your account is up to date with payments?
EDIT: Check to see if there are outages in your area.
https://www.telus.com/en/mb/outages
If you're still having issues, reach out to a CS Agent
You can submit ticket by direct message:
02-02-2025 12:25 PM
02-02-2025 12:19 PM
02-02-2025
12:03 PM
02-02-2025
03:20 PM
computergeek541
02-02-2025 12:03 PM
