11-09-2022 07:22 PM
Hi my sons phone is saying no service, I have re started it, turned the airplane on and off, reset the internet settings and now I have bought a new Sim card from Amazon, added the new card number to public mobile and restarted the phone and it still says no service. Is there a waiting period for this to activate?
11-19-2022 12:38 PM
Hi @shannongrice yes, I did see some post confirmed PM might pay you back the cost of a replacement sim card. Just open ticket with them
11-19-2022 12:35 PM
Sounds like a SIM issue if it does not work in another phone. Telus guarantees their SIMs....but does PM? I would approach PM right now and if CSA says it is a SIM...then see if they will credit your PM account for $10.
11-19-2022 10:59 AM
I did change it and it says active, and I tried it in my phone and still nothing
11-19-2022 10:58 AM
The sim won't work in my phone either
11-09-2022 08:57 PM
If you login your son’s account and it show that it is Active.
It is very rare that it is a SIM is defective and you didn’t need to replace.
Chances are that it could be an outage in your area. Check outage map:
11-09-2022 07:44 PM
Have a look at devicecheck.ca to rule that out.
11-09-2022 07:32 PM
You changed SIM cards in self service? What is his account status in self service….is it Active.
What happens if you put the SIM card in another unlocked phone?
11-09-2022 07:32 PM - edited 11-09-2022 07:34 PM
I presume he once had active and working service with Public Mobile?
Is the device (edit: his phone) a new one, or was it purchased used from an unknown source?
