06-01-2023 01:45 PM
Hi,
I recently became a public mobile customer and transferred my number. It’s been longer than 5 hours but my phone still says i have no service. When i check on the app it shows that my number was successfully transferred so i think there was an issue with the esim. What do i do?
06-01-2023 06:09 PM
Is there any number I can call for this issue or do I just have to wait to get a message from them?
06-01-2023 06:03 PM
@Mb797 No, you need the QR code 😞 You paid $5 for the eSIM and that is where the $5 for 🙂
06-01-2023 06:01 PM
Is there any way I can install it now on my own? Through the app or anything? I can see my sim card number on the app, can I use that at all?
06-01-2023 05:59 PM
@Mb797 the QR code process is much needed for eSIM, it install the eSIM profile on your phone.
there have been some eSIM activation issue. I hope yours got sorted out quickly
Let us know
06-01-2023 05:57 PM
Hello,
I have tried restarting my device. No, I did not receive a qr code. I have opened a ticket. Thanks for the help!
06-01-2023 03:10 PM - edited 06-01-2023 03:11 PM
@Mb797 No service is not a porting problem. Even porting is not completed, you should still be able to use the phone for outgoing calls and text and data, just no incoming
So, you need to submit a ticket with PM support, porting team number won't help. It is a sim card provisioning problem or eSIM profile installatoni. Did you get the QR code and installed it?
Try to reboot your phone and Reset all network.
if still not working. Please open a ticket with Support:
06-01-2023 03:07 PM
@Mb797 try to reboot your device
06-01-2023 01:48 PM
@Mb797 It sounds like there have been some issues with ESIM as it just got rolled out for PM. Did you try restarting your phone and seeing if that makes a difference? If not I would suggest you contact the CS Agent. You can reach them at this link by sending them a private message.
06-01-2023 01:46 PM
@Mb797 Will private message you a number for live support to help with porting issue
