08-21-2021 10:47 AM - edited 01-06-2022 03:12 AM
I ported from Shaw but cant receive text or calls. No response even after messaging multiple agents. I want to quit the service now. I cant do that if my incoming text doesn't work!
08-22-2021 10:28 PM - edited 08-22-2021 10:28 PM
@djohn wrote:I ported from Shaw but cant receive text or calls. No response even after messaging multiple agents. I want to quit the service now. I cant do that if my incoming text doesn't work!
Was this a Shaw landline?
If you ported from a landline it could take up to 7 days to complete.
Make sure you do not cancel your previous provider's services.
Incoming calls are usually the last to port over.
See helpful info. here: https://www.publicmobile.ca/en/bc/get-help/articles/port-fraud-protection
Four days is a long time with no response from a Public Mobile ticket. Response to the ticket again and inquire the status.
08-21-2021 11:14 AM - edited 08-21-2021 11:18 AM
@djohn Yes, if you are missing incoming calls and text, it is an indication that porting is not completed. Please call the number I sent you in the Community inbox (envelope icon on the top right)
it's Porting team, live support, they will confirm what is missing with the porting process
08-21-2021 11:10 AM
Only incoming talk and text is not working
08-21-2021 11:09 AM
yes I did. Only incoming talk and text not working
08-21-2021 10:56 AM
@djohn wrote:The SIM transfer was done in store by the agent
what you meant by done? usually they just put in the request
you need you receive an SMS on your Shaw SIM and reply Shaw that you allow the porting. Did the agent help you?
best is to call the porting team and confirm the status and see what steps are missed.
Will message you PM porting team number. Check you Community inbox on the top right
08-21-2021 10:54 AM
@djohn...so did you get a text message from previous network validating your port request ...to which you confirmed ?
08-21-2021 10:51 AM
08-21-2021 10:50 AM
You must leave the old sim in the phone until it quits and then put the PM sim in to start your service.
