04-28-2020 09:27 AM - edited 01-05-2022 11:47 AM
Hi, my husband and I use auto pay for phone service monthly, but yesterday service was suspended due to insufficient funds. I use our credit card with auto pay. I have not had a problem until now.
05-06-2020 07:58 AM
Problem solved, needed new expiry date on credit card. Tku
04-28-2020 02:11 PM
To avoid this issue going forward follow @Staliger advice just above your post.
04-28-2020 02:06 PM
The only way I was able to get around this and avoid additional service fees (as per the third party payment providers) was to use a second credit card. One that I never use otherwise, with the same bank / company / billing etc.
Not everyone has a second credit card, and expecting them to absorb processing fees from a third party retailer is ridiculous, particularly when it's an internal billing error. There's nothing wrong with the card that failed to be processed. I used it yesterday and an hour ago in store to confirm for myself, after taking time out of my busy day to call the bank this morning, no less.
There has to be another way to handle things like this than instantly suspending an account with no warning, especially when the issue is not on my end. It was stressful not having my phone work this morning when I really needed it. I'm really disappointed and unimpressed.
04-28-2020 12:42 PM
@Cathy63 Just remember that Autopay can fail sometimes. In order to prevent possible suspension, I recommend to do manual payments even with enabled Autopay.
04-28-2020 11:06 AM
I have the old limited texts plan. I turn on delivered notifications. When I send and I don't get the notification then I know I'm out of texts.
You can also buy vouchers online. There are a couple prepaid/reloadable type cards that work too. Koho has a relationship with this place.
04-28-2020 10:50 AM
@Cathy63 wrote:Hi, my husband and I use auto pay for phone service monthly, but yesterday service was suspended due to insufficient funds. I use our credit card with auto pay. I have not had a problem until now.
This is super unfortunate to hear. From what I have heard in the community and from oracles the best practice is to make sure you have enough funds in your account less rewards.
You can contact moderators and explain that auto-pay failed so that they know about this issue. I think this is a good idea for anyone that it fails for so Public Mobile can try and fix the problem.
You can purchase online vouchers as well: here are some instructions on how to use 611
Pay With A Credit Card
Please note you’ll need to pre-register a payment card via Self-Serve before being able to top-up through *611 with a payment card.
Pay With A Payment Voucher
04-28-2020 10:48 AM
Submit a ticket to a moderator by clicking on the question mark on the bottom right.
04-28-2020 10:44 AM
Yeah, my autopayment failed as well. Clearly an issue with the billing systems, as my credit card works fine with literally everything else.
I really needed my phone to work this morning and was expecting a call while out and about to pick someone up. No indication that the text message I sent failed. I was confused when my data didn't work in the car, as it usually prompts with GPS information, etc. I rebooted / power cycled my phone five times. Assumed maybe it was an issue with data only, not the tower, as SMS doesn't actually indicate if nothing was sent at all, so it looks like it worked. Until I tried to call eventually in confusion.
I couldn't find a store nearby to buy a prepaid voucher at. I'm not about to buy a prepaid credit card either just to work around that. That is completely unacceptable.
04-28-2020 10:17 AM
@Cathy63 good morning have you been issued a new credit card lately? If so it probably needs to be updated in your self service account that is one possible explanation for your service being suspended expiry date probably needs to be updated have a good day!!
04-28-2020 10:14 AM
@Cathy63 Try to reactivate your account by dialing *611 or online via selfserve. If your phone is still not working after making payment then:
Try the following to get plan re-activated again. (Just keep going down the list)
wait a couple of minutes and then declare your phone found by using the same steps from above and restart your phone.
If none of the above methods work submit a ticket to the Moderator Team for help. And purchase a voucher to get your account going again.
To submit a ticket to the Moderator Team, please start a conversation with the Public's virtual assistant, SIMon by clicking here or the icon (bottom right of your screen).
If you are still having problems contacting Public Mobile then click here. The link sends you to the private message function and adds the moderator team as recipient for a private message. You just have to enter a title and text in the body of the message describing the problem and post. The message will be received by the moderator team and they will respond to it. You will receive the response in your private message inbox.
04-28-2020 10:04 AM
@Cathy63 You may reactivate a suspended account online or by calling 611.
Via your account online
1. If you have already registered, or will first register, a credit card, go to step 2. OR deposit a voucher for at least your plan cost and go to step 3.
2. Go to the payment tab, select single payment and amount due.
3. Select the reactivate account button.
4. Restart your phone.
or Using 611 to make your payment( you need your 4 digit pin to buy an add on 😞
1. press 1 to make payment
2. press 2 credit card ( or 1 voucher)
3. press 1 amount due.
Stay safe.
04-28-2020 09:44 AM
@Cathy63 , try going into your account and doing a manual top up and manual payment. If things don't work, try removing the credit card and re-adding it. If all else fails, there may be a lock on the credit card in which case you will need moderator team assistance. The moderator team can be reached via private message using smartforms which is initiated by clicking on the ? on the lower right corner of the webpage or try using this link. The guided process will facilitate documentation of the issue or concern and the required resolution which will be submitted to the moderator team. Refer to this announcement link for additional details on smartforms and the ticketing system for moderator team interactions. If use of smartform brings no joy, then use the following direct link to private message the moderator team. Refer to the following knowledge base article for additional information on the moderator team. Good Luck.
04-28-2020 09:40 AM
By dialing *611 on your device, you are able to make a payment using the automated phone service. In order to make a payment using the automated phone service, you need to have a payment voucher or a registered credit card.
04-28-2020 09:36 AM - edited 04-28-2020 09:47 AM
Sometimes autopay fails. You can make a manual payment in your self serve account. Also you could either purchase a voucher and call 611 to make a payment or use recharge.com or ding.com but there is a service charge.
