No incoming/outcoming calls
Tonya22
I can't receive or make out going calls.  Also anyone without an iphone can't receive my texts nor can I text them.  Only imessages work.
It's been over a week.  I have turned the phone off and on, removed Sim card.
I have called the porting number and they say my number has been ported.
Thinking I should just cancel my public moblie and go somewhere else
12 REPLIES 12
fujiyama
Maybe give the suggestions from this link a try.
Also try deleting all previous Carrier Profiles under Settings -> General -> Profiles.
Hello @Tonya22
Check to see if your phone was added to be blacklisted, here:  https://www.devicecheck.ca/check-status-device-canada/
Also, was your phone locked to its previous provider? If so, you will need to contact them to unlock it for you.
@Tonya22...are you able to try that sim in a different phone...to see if the problem is phone-related ?
Let us know if anything helps.
Tonya22
I just did again and nothing??
I have been doing this all week hoping it would kick in.
when I try and call out it says Public mobile here......your call cannot be completed please check the number.
When I try and call my phone it says it goes straight to my voicemail.
@Tonya22   can you reboot once more and check if you can make outgoing calls?
Tonya22
It shows Pulic mobile and signal is strong.
Data works no problem
Tonya22
My account looks good.
The porting number I called signed into my account and said everything looks good.
It's sooo weird that I can't figure this out.
will13am
@Tonya22 , have you checked your self serve account to make sure everything looks in order there?  Usually, incomplete number porting affects incoming call functionality.  Calling out should work.
@Tonya22   You cannot even make outgoing calls?
What is it showing on top of the phone screen? do you see Public Mobile on top? How about the Signal level?
Tonya22
And I have called the porting number and they say it's been ported over
Tonya22
No it doesn't work with the old sim either
hairbag1
When you put the old sim back in your phone...does it still work ? Can you make a call with old sim in the phone ?
