10-25-2025 02:40 PM
I ported my number from Rogers yesterday. When the port was complete it worked for 15 minutes.
Then I couldn’t reply to non iOS texts.
Now my phone won’t connect to the network at all.
any guidance is appreciated!
10-25-2025 03:22 PM
@NotSkywalker wrote:I ported my number from Rogers yesterday. When the port was complete it worked for 15 minutes.
Then I couldn’t reply to non iOS texts.Now my phone won’t connect to the network at all.
Hello.
One thing you can try is this.
Go to Settings > General > Transfer or Reset iPhone > Reset, and then select Reset Network Settings, then reboot the phone. If you have a physical SIM card, you can also take it out and try it in a different phone to re provision it.
10-25-2025 02:44 PM
here's a link to message your Customer Support group..
