New public mobile subscriber
Ofel
Almost 24 hrs i can’t make a call and can’t be called after i subscribed and pay, any help ?
13 REPLIES 13
@Ofel wrote:
Yes, I talked with my previous provider (Bell Mobility) they asked for port in request from Public Mobile. Thanks.
@Ofel
Check your private message inbox.  I will send you the phone number for the Telus team porting number.  May need to put back your Bell SIM card to receive the port request text from Bell.  Answer "yes" when you receive that text.
Ofel
@Ofel wrote:
Only incoming calls doesn’t work
@Ofel
Check your private message inbox for help from customer service agent:
They are PM employees that can fix account issues.
Ofel
@Ofel wrote:
My data and outgoing call is working except the incoming call which i cant hear a phone ring and the caller said it goes straight to voicemail.. Thank in advance  for the help.
Hey @Ofel
If I may add to this, try two things. Can you try your SIM card in a different phone to see if you encounter the same problems? Another option, which sounds like it may work, go into your settings on your phone, find the network settings and reset them and then reboot. This in theory should resolve issues you're having.
CSA_PM
Customer Support Agent
Hi  @Ofel
I will contact you in a private message...
Ofel
Ofel
cellularndatabis working now but the incoming calls doesnt ring to my cp and it goes direct to voicemail. Any help please.
@Ofel wrote:
Not even cellular wifi  is working
use of wifi isn't related to your Public Mobile account.
Wi-Fi is unrelated to Public Mobile's services.
Ofel
hairbag1
@Ofel
so did you use the Public Mobile app to activate your new account ? If so, did you initiate port from your (still active) old provider ? You must leave old sim in cell until you get the SMS from old provider.  You must reply YES within 90 minutes of receipt of port SMS message. Did all this occur ?
clipped from Help Files.....https://www.publicmobile.ca/en/get-help/articles/transfer-your-number
Do data and text messaging services work?  If no apsects of the service work, this could either be a compatibility issue or an issue with the account not being set up properly.  If possible, I would encourage tryng your SIM card in another device to rule out any device issues.
