3 weeks ago
I got a new phone. But my number (already with public mobile) won't transfer when I log in and install a new e-sim.
3 weeks ago
3 weeks ago - last edited 3 weeks ago
You need to download the PM app on your new phonez login. THE 2FA code will try to send via SMS , that is where you click Didnt receive code and then Send email (or you can choose Send Voice Message, then call yiurfr from another phone and check e voice mail to get the 2FA)
If you can login, go to Account ->Puchase Sim card and then choose esim to buy
3 weeks ago
Yes, I purchased the eSim through my account, but my phone number didn't transfer. And it's on my phone that has a broken, black screen (the old phone).
3 weeks ago
Try click Didn't receive code and then use Send email option to let the code send to email.
If you still cannot login, ask PM to help
Since you cannot properly login, you won't be able to open the preferred Chatbot ticket. So, you will need to message them here:
So to keep your same phone number on your new phone, download the Public Mobile App to it and purchase a new eSIM. Go to Account, purchase SIM card, Purchase eSIM.
If you had eSIM prior, the new one should be free. This way you keep your phone number.
