New phone can't send/receive text/MMS
popealexander
Switched from google.pixel to Samsung a71 and now can't send or receive picture text messages and the occasional regular text will also fail to send
popealexander
worked thanks
popealexander
Network reset seems to have fixed it. Many thanks
Does normal internet browsing work?.
You must have data turned on to send / receive MMS messages.
Check your APN settings and modify them if need.
Here's mine
Save it then reboot phone and try to send an MMS.
If they don't work you can try these.
gblackma
@popealexander try a network reset and restart your phone if it doesn't automatically do so.  Welcome to the community.  Stay safe.
Reset Network Settings SAMSUNG Galaxy A71
  1. Firstly, choose Settings.
  2. Secondly, go to General management.
  3. After that select Reset and Reset Network Settings.
  4. At the end choose Reset Settings and Reset.
  5. Well done!
Dunkman
@popealexander
Does your data work?  Talk?
Maybe try rebooting phone.  Network reset.
tabi159w
Do you have data turned on when you send MMS? Also, try resyncing your text messaging app to see if your issue with texts can be solved.
