11-08-2016 11:06 PM - edited 01-04-2022 06:09 PM
Q1. How do new customer choose PM phone number?
Q2. How many phone numbers choices are there for me to choose from?
Q3. What is the cost of me choossing a personalized phone number?
11-09-2016 01:32 PM
I think if you choose Toronto, the phone number will start wiht 437.
11-09-2016 11:23 AM
which numbers do they have for toronto area?
11-08-2016 11:56 PM
Not necessarily. Also I don't think PM has been allocated any 647 numbers.
11-08-2016 11:41 PM
so i guess everyone will be getting the same first 3 numbers and they can be recognize of being from public mobile ..e.g. 647-123-xxxx,
11-08-2016 11:39 PM
I can't remember that lol I never tried to keep goimg
11-08-2016 11:38 PM
how many times does it allow to refresh the numbers?
11-08-2016 11:31 PM
@yellow wrote:Q1. How do new customer choose PM phone number?
Going through the registration/activation you can either choose to have a new number or port an existing landline or wireless number.
If you choose to get a new number you select your area you are in and there is a list of about 6-8 if I remember correctly. Or they give you the area code and 3 digit pre-fix and you can try to pick the last 4 digits that you would like. It will let you know if it is available.
PM does not charge for a new number from what I have been reading
11-08-2016 11:14 PM
First you select which area you are located in.
This will then populate a list of numbers you can choose from.
You are given the option to choose the last 4 digits of your number, it will tell you if the number has already been taken
11-08-2016 11:09 PM - edited 11-08-2016 11:10 PM
There will be a list of numbers with the area code of the city you choose. If you don't like the choices you can click a button to load more numbers. If you want to try searching for the last 4 digits of a number I don't think PM charges anything for doing that.
