11-07-2016 12:49 PM - edited 01-04-2022 01:11 PM
I just activated my SIM card this morning on the $120, 90 day plan. Right now I cannot make or receive any calls, but LTE internet is working without issues.
Any ideas what is going on here? My APN settings have both text and data setup by default.
11-07-2016 01:21 PM
Have look in your APN settings; delete all but Public Mobile. If unable to delete, ensure only Public Mobile has the Type as "default", or "default,mms". Reboot and check again.
11-07-2016 01:17 PM
Ok great this looks to have solved the problem:
from @raymond00
Just came up with a solution to my problem.
I had set my network preference to LTE earlier today via the *#2263# code. I just switched it back to Automatic and I am still able to get LTE and now I can make and receive phone calls.
I'm on a Samsung Note 4. Hope that helps someone.
11-07-2016 01:12 PM
Thanks, but hopefully I don't have to perform a factory reset.
11-07-2016 01:08 PM
I think this thread might help you out...
http://productioncommunity.publicmobile.ca/t5/Phones-Hardware/Changing-Samsung-Phone-Info/m-p/53208
11-07-2016 12:59 PM - edited 11-07-2016 01:02 PM
This is a new number. I am using an unlocked Samsung Galaxy Note 4 (WIND Model). In Network Mode, my only options are WCDMA/GSM (auto connect), WCDMA only, GSM only.
How could I have LTE with calling? Thanks.
11-07-2016 12:53 PM
Hi @tk11!
Welcome to PM!
I am fairly sure its because your phone is in LTE only mode.
Are you using an Android device? Which phone are you using? You need 3g/H+ enabled along with LTE in order to make calls as there is no VoLTE yet.
11-07-2016 12:52 PM - edited 11-07-2016 12:56 PM
Did you port your number or new number?
