Never received refer a friend reward
Karen22
Hello, Can you tell me how I can connect with Public Mobile.  I referred a friend back in October 2021 and I have never received the refer a friend reward.  Thank you
7 REPLIES 7
Hi @Karen22   did you open ticket with PM CS Agent and they were able to add the referral bank?
HI @SvenRicky
these links are one time use only  😞
Yummy
Maybe your friend did not sign up with PM or did not provide correct referral code.
When you log in into self-serving account, if you do not see his phone's last 4 digits under your referrals, he did not use proper code.
Little bit late (since October) but he can try talking to the agent to enter proper referral code for his activation.
HALIMACS
@Karen22
I might think the chances are very slim for getting your 'friend' to get the CSA's to add your referral code some 4 months later, but they might.
Hi @Karen22 , did you check if your friend ever got the $10?
your friend supposed to be the one open the ticket for Referral related issue.  pls have your friend to ope tixket with PM using Chatbot.  Just follow this:
    Type: My rewards are missing,
    click on "Refer A friend",
    click on "Yes, I'm the referred customer',
    click "Click here to submit a ticket" .
@Karen22  - October 2021?
You will need the person who activated to submit a ticket to CSA. Maybe they can add if for you going forward, but how knows.
To contact the Public Mobile Customer Support Agent (CSA)_Team, there are two methods to reach them:
1 -  Faster - Click the bubble comment circle on the bottom right-hand side of your screen,
or use this link to: Get Help With SIMon the Public Mobile chatbot
OR
2 – Slower - Use this link to:
Contact Public Mobile Representatives (CSA) by submitting a message(ticket) to them here:
Private Message to Public Mobile Customer Support Agents (CSA)
