06-09-2025 11:02 PM
My present mobile service is the hosiptal that I work and I know the service is Rogers. My hosiptal bill account number for the mobile plan start with a "S" and I cannot put it into public mobile website transfer form, there is a Roger's PO number in the bill, I am not sure if that is the account number with Rogers. Should I use the IMEI number of my present phone for the transfer? Thanks.
06-09-2025 11:33 PM
@apvmtan wrote:I transfered my PC Mobile number to the hospital account 5 years ago so there shouldn't be a problem on allowance to port it out and the plan with the hospital is only 5 years and no extention. I tested the transfer with my wife Public Mobile account (will not confirm it) just wanted to know what information Public require. They need the phone number and either IMEI number or account number. That is why I ask if IMEI is possible.
Using IMEI is certainly possible. It's just that it fails more often. For some number porting requests, using the IMEI is actually the proper thing to do (porting from Ztar Mobile is a good example of that).
06-09-2025 11:15 PM
06-09-2025 11:05 PM
do not use IMEI, most the time it has problem
you should make sure your hospital allows you to port out the line, then call Rogers and ask for account number and come back to PM to port
or if you like, you can also pick a new number with PM first. After the line is activated, you can go back to My Account->Profile->Transfer phone number and request porting. I believe they won't ask you account number that way. Or you can open a ticket with PM at that time and ask them to help with the port
