Need a cheap plan for one day to port out
UMM1
My plan expired today, but I want to port my number out and want to spend less than $30 to do so.
Are there any options?  I should be able to choose a cheaper plan than $30.
UMM1
Great, thank you!
@UMM1 wrote:
Can't even do that, as I can't receive the 2FA... at least I'm logged in in my web browser though.
$30 as a minimum plan for captive users is really quite lousy.
If the option isn't there to send to your email, you can ask a CS Agent to fix that part.
Please use this link to the Public Mobile Chat Bot which will direct you to creating a trackable ticket. Enter CONTACT US into the chat and follow the prompts.
hi @UMM1
try click Didn't Receive code or Resend code and see if Send email is an option
UMM1
Chalupa_Batman
Hey @UMM1
If you have the app on your phone, go into subscriptions and see what the lowest plan is and switch to that. Sadly that's the only real option.
