01-14-2023 06:00 PM
01-14-2023 06:43 PM
@LauraL if you login My Account using Incognito mode, what plan is it showing??
if it is $40 plan, PM has been sending out promo text earlier for that plan, all people need to do is to reply YES. Some people responded YES by mistake.. check your text history
01-14-2023 06:40 PM
01-14-2023 06:11 PM
@LauraL wrote:As above.
What 'as above'?
Are you saying your plan has changed from 1GB to 15GB?
Then you must accepted PM offer for an upgrade. Check what your account says - what plan do you have right now.
01-14-2023 06:03 PM
@LauraL @Did you happen to reply yes to one of the promotional text pm sent out by any chance
