08-20-2021 05:43 PM - edited 01-06-2022 03:12 AM
08-20-2021 05:49 PM - edited 08-20-2021 06:03 PM
No, it will not cost him extra, meaning unlimited incoming calls (does not use his minutes). 😃
08-20-2021 05:45 PM - edited 08-20-2021 05:48 PM
Hello @pewee
It will not charge your husband ANYTHING to receive any calls from anywhere around the globe, as long as he is in Canada.
EDIT: 100 minutes will only be deducted from his plan if he makes outgoing calls.
NOTE, also checking voicemail uses the outgoing minutes.
BUT, there is a work around...if you can call the number from another device or landline or create a free fongo account to check voicemail - this WILL NOT use your outgoing minutes!
08-20-2021 05:45 PM
