My data is being used even though my phone is physically turned off
grandie1
But it’s showing multiple usages
2 REPLIES 2
Meow
It used to be that PM will use some of your data for buffering or whatever but then you will get that data back. It is minimal usage so nothing to worry about.
Assuming your phone is NOT on during night with DATA on????
@grandie1
you meant some usage you see around midnight?
PM does not update the data usage constantly.  In fact, it only update it twice a day.
So, any entry you see is just a total usage between that timestamp and the timestamp of the previous entry.  The early morning usage  you see on the Usage log does not mean it was used in the morning but a total usage for the last 12 hours.
Also, for correct usage reading, always use Incognito mode to login My Account to avoid reading cached old info
