My account is suspended.
ling1104
My account is suspended for no reason today. Yesterday I just bought this SIM card and number. I can not use my phone now. Does anyone know the reason? Does it happen often?
1 ACCEPTED SOLUTION
Accepted Solutions
0PX9O4
@ling1104
Please send a private message to CS_Agent with your account details, and they will get this fixed, usually within a couple of hours.
It's unusual for a problem like this to occur, but once you're set up (especially if you have autopay configured), it should be smooth sailing from there on out.
12 REPLIES 12
0PX9O4
@ling1104
Do you still have service? If so, you can ignore the message in self serve, it's a known error.
If you don't have service, did you port in a number from another carrier? And if so, did you reply "yes" to the porting confirmation text at your old number?
HALIMACS
@ling1104
Did you port your number from another provider?
If so, did you reply yes to the port authorization request?
ling1104
No service. I can not call, text, or use data. I paid the new number but turned out to be useless.
0PX9O4
@ling1104
ling1104
I did not port my old number. I chose a new number when activating my account.
0PX9O4
@ling1104
Did you send that private message yet? Please keep us posted on the progress.
What does your account status says when you log in into self-serving account?
dabr
@ling1104    Do you mind explaining a little more when you say you just bought a new SIM?  Is this a brand new activation or were you trying to replace your previous SIM card?  If the latter then did you log into your account and select Change SIM on the right hand side of the overview page and added the new SIM to your account.
If this is a new activation, was the service working for a while before it stopped?
You could try rebooting your phone, toggling airplane mode on/off or powering off  your phone and removing the SIM and and reinsert after couple of minutes to see if it helps.
@ling1104
Did you power off your phone when you put the new PM SIM in the phone?
Try powering off the phone and wait a few minutes then power the phone back on.
