01-15-2023 12:55 PM
Hello, I tried to cancel my account , but don't see the option, so I deactivated my account. But I noticed you charge me $16.75 on Dec 19, 2022.
I still don't see the option to cancel my account. Please refund for the Dec charge and cancel my account.
Helen
01-15-2023 01:18 PM
There is no such thing as 'deactivating' account.
If you have autopay PM will continue charging you.
If you port your number to other provider then your account is immediately closed.
If you remove autopay then your account will be suspended on next renewal and closed after 90 days.
01-15-2023 12:59 PM - edited 01-15-2023 01:00 PM
How did you deactivate your account, there is no option to do so in Self Serve.
Unticking the "enable autopay" under the payment tab in self-serve is the only way to ensure your credit card is not charged any further.
Other than that, porting your number to another mobile provider also finalizes your public mobile service.
01-15-2023 12:58 PM - edited 02-17-2023 08:26 AM
hi @CommUser how you deactivated? the only way to do that is to disable Pre-authorized payments. If you have disabled, PM would not charge you again. Unless you disabled it after Dec 19
Jan 18 is coming up, would be a not payment due login My Account and confirm you disable it
01-15-2023 12:56 PM
@CommUser @Can you log in to your account try incognito mode there are cache issues and go to payment tab and disable auto pay
also if your owed a refund you need contact support
