01-26-2022 10:51 AM - last edited on 01-27-2022 09:31 AM by Dunkman
01-30-2022 12:38 PM
@bradecclestone - is your account in nonpay/suspended status? If so, for how long?
After 90 days of suspended/non-payment status, your account will be permanently deactivated, which means you will:
1-Lose access to your phone number (and Self Serve account), any rewards or Available Funds balance that was in your account at time of suspension, and won’t be able to transfer the phone number to a new provider in the future.
2-Need a new Public Mobile SIM card if you decide to activate a new Public Mobile account.
Otherwise, see other members posts.
01-26-2022 12:39 PM
Do you still have services? If yes, this could be your account going through the normal renewal process. The SELF SERVE account can say "expired" or "suspended" on the day of or before your plan is due to renew. So, if this is the case, ignore these messages on your SELF SERVE account.
If you have no services, and it is past your renewal, maybe your autopay failed?
Add Funds to your Plan Amount through SELF SERVE (or by calling 611 if you have a card registered)
Go to “Plan and Add-Ons” TAB
Select "Lost/Stolen Phone" TAB
Select "Suspend Service" BUTTON
Then, Select Resume/Reactivate Service
Reboot your phone.
01-26-2022 10:59 AM
@bradecclestone : Your login self-serve account? Or your services? Can you login?
01-26-2022 10:53 AM - edited 01-26-2022 10:55 AM
Do you still have service? If so, you can ignore the suspended message, it's a known glitch in the system.
If you don't have service, you can just add $1 more than what is sufficient to cover your plan. That should restart your service.
Alternatively, you can add just enough funds, and report your SIM as lost/stolen, then restore right after. That will also trigger restarting your service.
