My 3g won't work
DevikaAnderson
I bought extra 3g add ons on September 4th after my data wouldn't work. And it hasn't worked, even though my subscription renewed only on Aug 24th.
Meow
I do not see that particular '3G add-on' in a add-on catalogue. You can buy minutes or data. Even lowest $15 plan is now 4G so I am confused what add-on are you talking about...
golfball
Heads up, if your phone only supports 3G you may need to upgrade to a 4G or 5G device as 3G is being shut down gradually in Canada.
hi @DevikaAnderson
Reset network settings first.  and make sure your turn off Mobile data limit
If same, please submit a ticket with CS Agent using this Chatbot link: https://widget.telus.tiia.ai/publicmobile/publicmobile.html Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit by direct message:
Meow
Check your PM account and confirm you DO have add-on added and it is not exhausted already.
Do hard reset of your phone (turn off, wait, turn on).
