My 3 Accounts
TEY2
Hi, I am having trouble remembering the email addresses of 2 of the 3 accounts I have.
the public mobile numbers are
613-xxx-xxxx    709-5xx-xxxx
709-7xx-xxxx - this number I have no problem
i need the information because on one of them, I have to enter the new credit card information.
Edit by Dunkman: removed personal information
TEY2
I messaged them. Thankyou
Sansan
All 3 accounts need to have separate email addresses, yes but you can use the same password for all 3 accounts. That's what I do.
Be sure to write them down or keep them in your phone calender once you get access for future.
hi @TEY2
please remove the numbers, this is just a forum for customers. click the down arrow and select Edit Message and you can update your post
if you are unsure about the login email, try click Forgot Login
if that does not help, then ask PM support agent for help.  You can submit  ticket by direct message:
slusagm
remove your phone numbers.  We are here just customers, not PM staff, and we have no access to your account.
you need to work with PM to get that sorted out
 Since you cannot properly login, you won't be able to open the preferred Chatbot ticket.  So, you will need to message them here:
