Move my public phone number to a new public account
Laura2356
My aunt has my public mobile number under her public account. I want to start my own account and move the number and plan to my account. Is that possible?
ShawnC13
There is no way to have multiple numbers under one account.  So your account is already all alone.  All you need to do is talk with your Aunt and change the payment method to your credit card and change the information on the account.
HI @Laura2356
account swap cannot be done
But PM is just a prepaid service, the account does not have much to tie up to the person
What you can do is to ask your aunt to give you the My account login.  You login to the My Account and update the profile information and update the credit card payment
you would likely want to ask PM support to change the email tied to the My Account as well so you can use your own and receive 2FA code on your own email, please open ticket with CS agent for email address change:
at : https://publicmobile.ca/chatbot.
First type Contact,
from the list of , choose "Other"
Yummy
You CANNOT transfer PM number/account to another PM account.
If you want to have HER account/number then: change address, provide new credit card and ask agent to update email so you would basically take over her account.
Or you would have to open brand new account and chose number.
Sorry, but there is no opiton for this and Public Mobile won't allow this, but you could have your aunt change the account so that it's under your name.
