09-14-2023
02:11 PM
09-14-2023
03:34 PM
computergeek541
Hi there,
I will be travelling to Spain in November, and will need to call the hotel to get access inside while in Spain.
Would I be able to make this phone call while in Spain?
09-14-2023 02:12 PM - edited 09-14-2023 02:13 PM
@oreooo Sorry PM won’t work in Spain your best to get a local pre paid SIM card in Spain
Add PM only works in Canada and the US with US roaming add on or a CAN /US plan
You will need to get a travel e-sim or sim from a different provider in Spain. PM with international long distance only works for calls made within Canada or calls within the US if you have a roaming add-on or Can-US plan
