12-13-2016 04:05 PM - edited 01-04-2022 01:24 PM
I recently ported from Rogers and everything seems to be working now except picture/video messaging.
Will MMS work on iPhone 4 (iOS 7.1.2)? I'm unable to upgrade to iOS 8 or higher. I've seen a few posts mentioning the same issue but can't find a solution.
Any help would be greatly appreciated! Thanks.
12-13-2016 07:12 PM
Yes, MMS Messaging is on. It was working on Rogers so I'm not sure why it's no longer sending or receiving picture / video.
12-13-2016 06:11 PM - edited 12-13-2016 06:12 PM
Is MMS turned on? I belive my friend had a similar issue and i think it was that MMS was turned off. not an apple guy so i could be way off...
12-13-2016 05:23 PM
I accessed http://www.unlockit.co.nz on my phone, selected Canada, Public Mobile then "Create APN". I installed APN Carrier Settings so it's now ap.mb.com. Data works but I'm still unable to send MMS. Anything else I need to update?
12-13-2016 05:04 PM
iPhone 4 APN settings cannot be updated manually. You will need to connect to wifi, access APN iPhone 4 with Safari, then follow the directions there.
Let us know how you make out.
Good luck.
12-13-2016 04:31 PM - edited 12-13-2016 04:33 PM
It should work. Make sure your data is turned on to receive and send MMS. You might need to make sure APN settings are correct.
