Lost phone
Larry221961
If I order a new SIM card cause I lost my phone will I still be able to keep my same number
Quigley
@Larry221961
Yes, you can still keep your current phone number with the new sim card.
Just login to your account and do a sim card change.
Just don't try to activate the new sim card, as if for a new account.
JK8
@Larry221961
Yes you can. Once you get the SIM card go into self service and you can do a change SIM card.
Yes, you would be able to.  There is an option in your Self Serve account profile section to perform this action.
