10-21-2025
09:24 AM
10-22-2025
12:18 AM
computergeek541
Hi there, my husband lost his phone. He's going to have to order a new SIM I guess. The problem is, when I log into his public account, it says that it is going to send a code to his phone, which then is inputted into the computer. The problem is, you can't get a code from a lost phone and I can't go any farther into account unless I put a code in. Any suggestions on how to access the account or does he need to order a new SIM and change his phone number? Thanks for any help.
10-21-2025 10:09 AM
unnecessary repetition
10-21-2025 09:34 AM
Check if email is an option to get the code
Click Didn't Receive Code or Resend code and Send email or Send Voice Message should be the available choices, you can choose either way
10-21-2025 09:27 AM
Hello there!
I sent you a private message.
You can view and reply to it by accessing this link:
