05-12-2025
05:43 PM
05-13-2025
10:39 AM
computergeek541
Need new phone and SIM card but wanted to keep phone number. How can I possibly talk to a Public mobile agent?
05-15-2025 04:37 PM
Can't log in as every time I log in it wants to send a code to my old phone and I can't get anywhere past that
05-12-2025 06:07 PM - edited 05-12-2025 06:10 PM
buy your new cellphone and get a Public Mobile sim. Use wifi to download the Public Mobile app to your new cell and log in to your account > Account tab > you'll find Change Your SIM card...click it and add the 19 digit sim number.
If you're in the GTA, call Canadian Cell Supplies as they have the Public Mobile sims for under $5.
added link...https://canadiancellsupplies.com/products/new-blank-multi-sim-card-lte-4g-5g-prepaid-postpaid-bell-v...
05-12-2025 06:07 PM
hi @Mouse65
you can try to login My Account and update the sim number
but since your phone was lost, you cannot get the 2FA. So, click Resend code or Didn't receive code first, then click Send email or send voicemail to get the code via email or via voicemail (call to retrieve the voice message from another phone)
But if you still cannot login, ask PM support agent to help.
you can submit ticket by direct message:
05-12-2025 06:03 PM
You do not need agent to keep your phone number.
Get a new SIM and transfer number.
Go to Profile where you can:
- Change phone number
- Change SIM number
- Transfer Phone Number
Then get a new phone and stick new SIM into it. All done.
05-12-2025 05:50 PM
you can definitely keep the phone number
get a physical sim first. Buy a Public Mobile sim from Telus or Koodo or MobileKlink store for $10 , or buy cheaper from Amazon for just $5
after you got the sim, just ask PM to update the sim card to the new one by ticket. Since you cannot properly login, you won't be able to open the preferred Chatbot ticket. So, you will need to message them here:
