Losing a Referral if they change phone numbers?
WoozyPolarBear
Do you lose a referral from your monthly rewards if the referral makes a phone number change by either porting in a number or just simply making a number change, but still remains with Public Mobile with the same account number?
hamzarizvi97
The referral is for the account so it won't matter if they change numbers or not 🙂
jotsang
No as it is linked by account number and not phone number.
chrisbasm
@WoozyPolarBear  No, you do not loose referral.  It is tied to the account, not the specific phone number.  You should see their new number after they change it.
