11-12-2016 04:37 PM - edited 01-04-2022 06:16 PM
11-12-2016 04:40 PM
11-12-2016 04:43 PM
Hi..
i was just last week there and had no problems.... make sure that if you call using your phone book feature, that the phone did not add +1 by default...
if you checked that, then yes, this might be a glitch...
cheers
11-12-2016 05:19 PM
Im in Ontario and I had the same problem. I saved the number wrong which was why it stated that it was long distance. Check that before contacting PM.
11-12-2016 05:22 PM
11-12-2016 05:27 PM
yeah.. Tsawwassen has always been a "grey" area as sometimes it is trying to log into an USA server due to closeness of border...same as ferry terminal or even on the ferry......signals from usa and canada are crossing eachother once in a while....
11-12-2016 05:43 PM
11-12-2016 06:48 PM
Your phone should not be interfering with a US tower, as PM still does not have roaming available, and therefore should not even see the US tower.
i had a problem calling a number in my area code, but a different exchange, still same city. I had to get PM mod to have the tech team allow the number to work, as it was the most local call I could make.
11-12-2016 09:01 PM
11-12-2016 09:15 PM
The exchange is the second set of numbers. For example, 226-922-XXXX is the area code and exchange for a number in my city. 226-227-XXXX is another number exchange for my city.
these are not long distance calls, however I had to ask PM to fix the problem for me.
as I read your last message, it appears this isn't your particular problem, as you say it's intermittent.
