07-15-2022 01:25 PM - last edited on 07-15-2022 05:20 PM by computergeek541
I forgot my password, made too many login attempts, and don't receive any codes when I try to reset my password using either my phone number or e-mail. Help!
07-15-2022 02:35 PM
Just in case anyone else can benefit from my stupid mistake, here's what happened to me: I thought I'd registered for my Publicmobile account with one e-mail, but I'd forgotten that I'd actually registered with a different e-mail. I was attempting login with the wrong freaking e-mail *facepalm*
So, be sure that you're attempting to log in using the right e-mail 😉
07-15-2022 01:37 PM
Thank you! I have sent a PM.
07-15-2022 01:33 PM
Thank you. The chatbot says wait three hours and then try to reset. Will that work?
07-15-2022 01:31 PM
@livintheilife Hi you may need to wait 3 hours for a reset if nothing works
1. you can open a ticket through Simon here https://publicmobile.ca/chatbot.
type request email password reset
2. alternatively you can private message them here
07-15-2022 01:29 PM
Contact agent for assistance. No other way if your account is locked due to too many login attempts.
To contact CSA-agent, there are 2 methods:
If ticketing does not work very first time, contact agent directly.
