Keep phone number but change sim card
Landryy
Good morning and HAppy new year.
i have lost my SIM card and purchased a new one but I would like to keep the same number. When I try to change the SIM card as indicated, I am not able. Please help
thank you
@Landryy - you said you are not able to? Is that because you listed your phone into lost/stolen status and it is still in that status?
If so, resume/reactivate service, then you should be able to swap out the SIM card. If still issues, resume/reactivate, log out of My Account, then log back in and try to swap it.
HALIMACS
@Landryy
  1. login to self serve after going incognito or private tab
  2. go to Profile on left side
  3. go to Edit Account Info lower right
  4. there you can change the SIM card.
@Landryy - do not go through the SIM card activation process. This will create a 2nd account and you do not want this, then you will have 2 paying accounts.
See "How To Change Your SIM Card" at the bottom of this Help Article: https://www.publicmobile.ca/en/on/get-help/articles/sim-swap-fraud
If issues with your My Account, click here to request a SIM Swap with the Public Mobile Customer Support Agents (CSA): Submit ticket for a SIM SWAP
LoveNature
Hi @Landryy
your number in your account and just you need to get new SIM card and Login to your account and change SIM card,
@Landryy  Yes you need to SIM swap the new SIM card and do this on computer
My account
Legend  and features
Change plan / update cc /auto pay
Account #/ change # port /swap SIM
