08-02-2017 11:32 PM - edited 01-05-2022 02:34 AM
08-03-2017 06:16 AM
@Tricket56, you can upgrade to the desired plan by using the future dated option, the one one the right of the screen when you change a plan.
You would be completing your current cycle, but would still qualify for the plan at the renew point by doing this.
08-02-2017 11:49 PM
@Tricket56, prepaid has no refunds. If you want to change a plan immediately, you forfeit the previous plan and payment. That is the way it works. Fortunately, the moderator team is good about applying corrections for customers at no charge. What I suggest you do is send a private message to the moderator team explaining your situation and they will be glad to put you on the correct plan without you having to pay twice. Click on this link to private message the moderator team. Refer to the following link for information on contacting the moderator team. Good luck.
http://productioncommunity.publicmobile.ca/t5/Knowledge-Base/Updated-Contacting-our-Community-Modera...
