Just arrived in the US. purchased a talk/text data plan. Not working. Can’t seem to find a network.
rogercrewe
16 REPLIES 16
rogercrewe
Thank you
@rogercrewe
You'll have to either send a private message to CS_Agent or get a ticket for help with that refund request.
Also FYI, those VoIP apps I mentioned before for talk / text are FREE and can be used with free wifi where you can get it.
HI @rogercrewe
for request refund, open ticket with CS agent
at : https://publicmobile.ca/chatbot. Follow this to get to ticket open screen quicker:
start by typing : Contact CS Agent
then Click "Contact Us"
then Click "Other"
finally Click "Click here to submit a ticket"
Go to top of this page and click Get Help / Chat with Simon to start process of CSA assistance. Watch the little envelope icon on top right side of page will be highlighted when they respond.
Good luck.
rogercrewe
Yes seems that way.Would you know how I Would go about getting a refund/credit.
It sorta sounds like the 10 Day US Roaming add-on was not successfully added. Try to find a wifi hotspot and log in to your account to confirm if that add-on is available for your use.
If it's not mentioned...you can try to purchase it now.
Let us know if this is the case.
walker1
Getting that add on to work in a reliable way will be a waste of time. Sorry to say.
rogercrewe
Just across the border in Houlton
rogercrewe
 I rebooted my phone. Didn’t help. Use crossed the border today. In Houlton.
Hi @rogercrewe   and do you see AT&T ?
you might want to check in another area of the city tomorrow and see if you see any of the 2 networks.
if not, maybe you have no choice but to use VoIP app like TextNow. and use it for voice call/text whenever you have Wifi
for the add-on you got, you can ask PM to cancel the add-on as you cannot use it due to network issue.
walker1
@rogercrewe
You might be way better off by installing a VoIP app like Fongo or Text Now and get pay as you go Data from a company like KEEPGO or GIGSKY or some other one.
Most people have better success doing that option.
HI @rogercrewe
Maine should have ok coverage there
2G
3G
LTE
Try to reboot your phone.
and what exact  city you are at?
rogercrewe
Texting is not working either.
@rogercrewe wrote:
 I am in Maine. T-Mobile did not show as an option.
Unfortuantely, without T-Mobile network availability, the "talk" part of your  roaming add-on won't work.
rogercrewe
HI @rogercrewe
You logged in to My Account and see the the roaming talk/text showing there?
Which states you are in now?
did you try to connect to T-Mobile or AT&T ? Connect it yourself , do not let it connect Automatic
Actually try to connect to T-Mobile first as it can use 3G (if exist) or 2G for the voice
